Invader_sk00dge
- Mar 31, 2005
Ok. Here we go. I have been a fan of the [H] ever since I found it, and found that it and its members provide useful advice. So here it is. My computer is having numerous problems. First of all, let's start out with the blue screens I keep having. One is a "Machine Check Exception" bluescreen. The only common factor in the instances when it happens is that it will only BSOD when I'm playing music. I'm in the process of narrowing down the problem. I switched from my Audigy 2 ZS over to my onboard sound. Another BSOD I am getting is from my 250 GB HDD. Anytime I try to access data off of it (with recovery console, setup for Windows 2k, 98, or XP, DOS prompt, or trying to boot) it will BSOD with an NTFS.sys bluescreen. Now I've looked both of these up on the MS knowledgebase and other sources. The Machine Check Exception could be anything. According to MS it could be my power supply even. The other BSOD (NTFS.sys) is caused by a corrupt file system on the HDD itself. So I'm at a loss here. This all started happening after I bought a Gigabyte motherboard and OCZ power supply. Now I'm pretty sure it has something to do with that as far as the Machine Check Exception BSOD. As a computer professional, I have been through a lot of computer problems and this one by far is the most stressful and time consuming one. What should I do? I'm just thinking of scrapping the Gigabyte and getting an ASUS. As of yet, it's the ONLY mobo manufacturer that has not caused me problems. So I'm at a loss here. Any and all input would be appreciated. Thanks.
