Ok ladies and gents, I have been lurking around here forever and finally needed some community help for my first over clocking adventure.
I am rebuilding my current rig. I am currently running a P4 Prescott 560 @ 3.6GHZ all stock. The only parts of the system that will be making the crossover to the new Core 2 Duo are the PSU, my Radeon X1900XTX512 PCIe and SB X-Fi.
I ordered a e6300 for the CPU as it over clocks well in 99% of the reviews. I have a Scythe Ninja cooler already which will be slapped on top of the Conroe.
I also order 2GB of G.Skill DDR2 800 memory and a Gigabyte 965P-S3 MB.
Here is the thing; I am content with the choices I have made for the time being as this is my first foray into the Dual Core arena. I am not, however a big over clocker (never have been) and I am not sure what I will need to do when I get the rig up and running. I will set it all up with OS installed and everything at stock until then.
When I prepare to over clock... what should I be doing in the BIOS? I am not looking to set records, just run the system a bit faster than stock. I have read the over clocking guide and am still a bit foggy on how to do what needs to be done. I am assuming the only thing I need to change is the CPU FSB Multiplier and the Memory Settings. Does this board have an auto setting for voltages or do they need to be done manually?
From my understanding, the DS3 and S3 are essentially the same board. Could someone running a e6300 possibly post a few screens of the BIOS setup they are running on that board? As I said.. I am just not very comfortable with this stuff yet and any help given would be greatly appreciated.
Thanks in advance.
Thanks in advance.
