I've had this Dually P3 board boxed up for a while. Its a MSI 694D Pro. A couple years ago it stopped working with both CPU's installed. With CPU1 installed it worked but wasnt very stable. I held onto it with some hope of getting it to work again. Not that its the fastest by todays standards but it has a geeky cool factor about it.
Last month I decided to check it out again. I saw that there were a few blown caps near CPU2. I found a recap kit for this mobo here: http://badcaps.net/ and decided to go for it. About an hour later I had all the caps replaced. The board is now running 100% stable with both CPUs. It's currently running SUSE 10 and folding [H]ard for the [H]orde. Im going to do some OCin once I get some better cooling for the CPUs. Maybe even do some dually water cooling.
Specs:
MSI 694D Pro
2x 1GHz P3
1GB PC133
Before:
After:
Specs:
MSI 694D Pro
2x 1GHz P3
1GB PC133
Before:
After:
