A little Confused
Aztlan
I plan to order a Coolermaster Praetorian case
and there are two versions
This one
and the 730 Version
I plan to order a side panel with the window, but the thing I am confused is that it just says for Praetorian Series
will that fit to either case?
or just the first one I link?
id get the regular praetorian, i prefer the classic look but you can go wrong either way :)
both are cool looking, but I think I am going to go with the 730 because it has better cooling,
