Hi,
I got a bit of a head scratcher. My rig in the sig seems to be acting up on me. I have a Gigabyte P35 based board. Right now it is clocked at 333 X 9 for a 3.0 GHz overclock. It is running on 1.18 volts which is also really nice. So I was playing with multipliers and low and behold I get a funky problem on a 400 X 8 set up. Yes I did up the voltage. I can prime stable with a bit of extra volts around 1.27 volts.
Now here is the funky problem. When I put my computer to sleep, there is no problem. It shuts down. When it is time to wake up, the computer fails to wake up. I have to power off to get a restart. However at a 333 X 8 set up, no problem. 400 X 8, problem. I have tried MCH and FSB voltage adjustments. EIST and C1E are disabled. As far as I can tell my BIOS is set up properly.
Right now I am back at 333 Mhz by 9. I am wondering if there was a problem with P35 based boards and lower multipliers. Anyone have a thought on this? Also on a slightly less related question, will going to a P45 based board be the answer?
Thanks!
Thanks!
