A graphic firewall like sygate ?
The current Sygate firewall I use has some problems from time to time.
Some websites run slow, and if I disable the firewall they run ok.
So probably in the future I will have to switch to a different firewall.
The problem is I tested a few and never found one with the same features.
What firewall has these features ?
- Like pop window asking about a In or Out connection and "remember this setting" - (that feature is pretty common though)
- a large graphic screen showing IN and OUT speeds in KB or MB and also a graphic chart
- very easy setup of complex rules
- a list of currently opened connections from and to applications (with lights activity) so you know what is going on
Here is a picture with this firewall. There must be a similar firewall out here. I think there are at least a dozen firewalls available.
