Canadian in Berlin
- Sep 8, 2007
I'm looking for a case in the $100-150US (or less) range .
I don't care if its quiet, but I'd rather not have a jet engine. I hate LEDs, I sleep in the same room and don't need a nightlight anymore, but I'm not completely against swapping out fans if the case is still good.
I currently have an "original" Antec P180... but I'm looking either for a new case for my wife (who is getting all my old parts which are currently installed in the P180) or for myself... You can understand that since my P180 has dozens of bloodstains from the original install... I'm not the most keen on taking everything out and putting new stuff in... It'd be easier just to remove the harddrives and put hers in.
So a new case...
What can you reccomend?
I looked at the Coolermaster RC-690, but I can't find it available anywhere in germany. The Antec 900 looked promising, but I read that it was a beast for cable management... nothing a little ducttape couldn't fix though, or? As far as dust... women's pantyhose make good cheap dust filters.
Fire away and I'll see if i can find it!
Thanks a bunch!
So a new case...
Thanks a bunch!
