Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
AFAIK.... they don't exist. There must be OEM units floating around that PC manufacturers use but I sure haven't seen them for sale. Somebody correct me if i'm wrong
I thought X=Qpack's used standard atx, therefore wouldn't an matx be too small???
The problem was fitting an atx psu with a standard length dvd/cdrom drive, you might be able to remedy that with a shorter dvdrom + low profile molex's.
Don't take my word for it, do a search for the x-qpack in the SFF for a ton more info.
