I think you need to clarify you're talking about PROJECTION CRT's, not direct-view. Projection CRT's do suffer from burn-in and a limited viewing angle, but direct-view tubes do not. No burn in, and you can see them from angles as extreme as 175 degrees. However, you're limited on the size of the direct-view, I think you'll top out at 40".magoo said:You speak the truth. I have a 46" Hitachi CRT HDTV and it is simply better than most anything else. Hitachi MAKES all HDTV CRTs(the tubes, not the cabinets and other hardware) and their tubes are the most reliable. The only downside to the CRT HDTVs is their size. They may also fall prey to "burn-in" if an image is displayed for too long.....like the football field on a madden game after a couple straight days ofa madden marathon.....I dont think this would be an issue with a FPS but I cant be sure.
CRT HDTVs are much cheaper however and the picture cannot be beaten. The viewing angle is a little small and should be set up with some thought to that as well.
They do fall out of focus if jostled, but Hitachi has the auto convergence which helps,but is not perfect.
Id look long and hard at Hitachi as well. I love mine. bought it from Sears and got a very good deal.
Personally, if you're going projection CRT, I agree with the above, go with the hitachis. Great sets. If you're going direct-view, get one of the super-fine pitch sony's. Best direct-view tubes made, period. I have a KD-30XS955 and a KD-36XS955 and they are unsurpassed in picture quality due to their superfine pitch tubes. If you shop around, you can get the 30" for less than $750...in fact, some bestbuy's still have them on clearance. Both are reference monitor quality and once properly calibrater, will destroy the picture quality of any flat-panel set currently made. The down side...they weigh 154# and 235# respectively, but the PQ makes them so worth it.
