a good 19 inch CRT
gamekid
well, theres a lot of talk about LCDs in this forum, so i hope u people remember anything about CRTs.....
i would like a nice 19 inch CRT monitor for around $200 U.S, i will go $250 at the highest but i would like to get one close to $200. i am a gamer, if that helps. i dont really know much about monitors so feel free to explain why one monitor is better then the other.
i was thinking about this one, but the reviews about the 2 lines turned me away from it
http://www.newegg.com/app/ViewProductDesc.asp?description=24-002-037&depa=0
I would like to add the Samsung Syncmaster 955DF as absolutely a great monitor ... Very good quality , clean and ofcourse flat screen ... you can probably find a lot of great reviews on them ...
omg .. i just saw those at new egg ... :eek:
I never knew they had newer ones ...
Ivory
Black
those look like great monitors, i will have to look up that dell, only $200 for a 21inch!!!! :eek: , seems a little fishy
shuttleluv hit the nail on the head,
ive got 2 VS P95f+ runnin on my desk
good luck,
-P
i looked up the dell, and that thing has brightness issues so thats a no, and i herd bad stuf about that viewsonic....and i see soooooooo many problems in reviews on monitors, so if i can get a higher quality 17 inch i will be happy......and if u see an LCD for the same price that is 12ms and good for gaming, i will be very happy.
I think the reason is, everybody is different. so one could be great to one person and terrible to another. Oh idk
well, if i can get a ride (i'm not old enough to drive) i guess i will have to go and check some monitors out at the local retailers tomarrow......i'll let u guys know how it turns out.
I just made a post in this thread comparing the p90f and 991SB
also about the 997DF mohammedtaha was talking about, I just went to circuit city yesterday to check that monitor out cuz they have it now for $199 (need a 2nd display to go with my p90f)
The overall image of the monitor is very nice, and it is indeed flat
But the only thing I didn't like about it was the one they had on display at circuit city had bad geometry at the bottom of the screen that couldn’t be fixed with the OSD
The bottom of the screen had a bad curve to it making it so when the image was adjusted to fit the bottom of the screen correctly, the 2 outside corners of the start menu were sticking about 1/18" up off the bottom of the screen when the center was aligned right
Don’t know if they are all that that tho
And it is a shadow mask compared to the 991SB which is AG
are their any monitors without lines and that arent distorted that can do 1600x1200@85 in my price range? because all of the monitors that i have saw that have a aperature grill have 2 noticeable lines and are distorted, the viewsonic that was $250 on newegg had a lot of review complaining about the lines and that the picture is distorted( if i see this in person and like it i think im going to get it because it does 1600x1200@85). should i just get a monitor without a aperature grill? although a aperature grill is better right?
ya AG is better
Did u read the thread that I linked to in my last post?
I’ve used many monitors that have noticeable AG lines, when u are first examining a monitor, ur like OMG what the hell are these lines I can't use this
But then when u start actually using the monitor, ur concentration isn’t on the lines, and after a while u don’t even notice them
A week after my sister got her 991SB she said she doesn’t even notice them anymore
just dont have ur desktop BG white or sumtin...whens its a lighter color, those lines are more noticable...but yea..they dont bother me...love my monitor...DP930
Ivory
Black
i have the 955 also and i love it.
I like Samsung also.. I've had a 900p for about 6 years now and never had a problem... I think it's about time for a new one.. I might check out the 955's. I would like to get an LCD but just don't want to spend the money on a good one that I can use for playing games... I hate seeing tails when I'm playing..
Samsungs are ShasowMask which means they are not perfectly flat screens. Id rather go with a higher refreshrate appature grile CRT
I don't know how much it weighs in at, but a monitor most people consider very nice (until they see my lcd beside it, that is) is a NEC FE991SB. The SB stands for Super Bright which is nice if you don't know how, or don't have the time to calibrate your monitor. Check those out at your favorite store (online or otherwise).
B
Hi.. proud owner of a 955SL here, i've had it for quite some time.. got it off buy.com and used a coupon to get it for around $300 shipped.
I've had two problems with the monitor.
1) fuzzyness on the very edges of the screen. very faint, but if you go in for the close up, you can definitely notice it. through tweaking with the OSD i managed to clean it up a little bit, but not a lot.
2) not a completely flat screen. i believe the 955DF fixed that, but mine has a curve to it. perhaps that's contributing to the fuzziness?
otherwise, it's a great monitor. it's currently sitting on my floor while i try out this 712n.
Hi, I've been going over the CRT threads furiously, I'm in the market for a new 19". Right now I have a KDS VS-195e, and its turning into a real piece of junk. It has terrible light grey scanlines at every resolution; clearly visible over lighter colors on the screen. I believe it uses a shadow mask. I'm about to go for the SyncMaster 997DF, because allstarshop.com has it for $206 and they are down the street from me so I can just will-call it and negate shipping. My main concern, as others have expressed, is the AG lines. What do they look like compared to scanlines? Are they just a few faint horizontal lines that don't move? If so I can handle that, as these scanlines cover my entire monitor.
well i have no idea what Ag lines are like but the Syncmaster doesn't use AG i dont think .. the only problem that was stated was a slight problem in geometry but u can walk over to the store and check it ... and see if it has any problems .. if not then u can buy one .. take it home .. try it .. and hopefully nothing is wrong with it
I was guna pick up a 997DF and use it as a 2nd display cuz Circuity has them for $199
But when I went to go look at them the one that was on display had geometry problems on the button of the screen
the monitor had a very nice picture and the screen really was flat, no round screen behind the flat piece of glass deal
the only reason i didn't get it was cuz of the geometry problem
otherwise, very nice monitor
and yes,, no AG lines at all, I bleave its a shadowmask monitor
Thanks for the replies.
I just got back from my local Best Buy and Circuit City, out of all the decent CRTs mentioned, they only had the Syncmaster 997DF (and their selection was sparse).
I noticed the geometry a little, and the picture didn't look truly flat. Also, the color was a little washed out and just didn't do it for me.
Thanks again for the advice to go check it out in person at a B&M first, I might have gone and bought it otherwise.
