Ok, so i bought 4 maxtor 200gb drives. I know maxtor may not be the greatest but at $50 new i couldn't pass it up. On top of that I have 2 other 200gb drives which are already in a raid 0 on my promise card in my computer. What I want to do is build a dedicated machine to use for network storage with a raid 5. Also, I can't clear my current raid 0, so I need to have the capability for online expansion so I can build the array with 4 discs and then copy the data over, and then add the other 2 discs. From what I've read, this is possible if the raid supports online expansion and it's formatted as a dynamic disk in windows.. The box will probably be running 2k3 server, which i think supports software raid 5. I don't want to do a hardware raid because the card costs money, and it would limit the number of drives i could put in in the future. My questions are:
1. Does the 2k3 software raid support online expansion? Also is there a better software raid solution out there than that?
2. What is the smallest case that will reasonably hold maybe 10 drives? 10 is my eventual maximum I think, since the mainboard I am looking at (asus p4p800 e deluxe) supports 10 hard drives total. I don't care if it sounds like a jet plane, but I need to be able to bring it to lan parties(leech festivals) which is why I want it as small as possible.
3. Can you guys recommend a power supply that's going to be able to handle that kind of load?
Thanks alot for any help you can provide.
-Richard
-Richard
