I was doing research for my first water cooling set up and stumbled upon TECs. I decided to try them as well and I have a couple of questions before I finish my ordering.
The system:
e6400
MSI 975x V.2
Wintec AMPX DDR2-667
OCZ 7000w
What I have so far for water(only cooling CPU/NB):
MCP355 With Petra Modded Top
Coolingworks Coolrad 32T
Silverprop Cyclone NexusSX
Swiftech Micro Res
What I want so far for the TEC:
Meanwell 320-12 PSU
320w 50mm Peltier
1. Which CPU Water block is the best for a TEC? Im currently looking at a Swiftech Apogee GT or Danger Den Maze4-1 TEC Version. Whats the difference between using a normal water block and one made for TECs? Does the TEC version come with anything different(mounting, insulation, ect.) that doesnt come with a normal water block?
2. Would it be worth it to add a second radiator to the loop, thinking a single 120. I know the TEC will be giving off alot of heat so I would think that it would help but Im not certain if itll be to much for my loop.
3. Any suggestions on Pump Relay Switchs or a delay timer? Ive read about these and want to use them but I cant seem to find them at a reasonable price. Any suggestions on where to look or specific models to look for?
4. I need some help with insulation also. Ive read how to do the back of the motherboard and around the socket. I havent seen any guides covering anything else and I would think the socket, water block, and lines would have to be insulated as well. Can you point me to any guide on total insulation?
The system:
e6400
MSI 975x V.2
OCZ 7000w
Swiftech Micro Res
Meanwell 320-12 PSU
320w 50mm Peltier
