A few questions about ZFS
lordsegan
I have pretty well decided on a ZFS file server, and have 3x 1TB 7200 drives to use.
I am thinking of buying 3x 2TB drives to add to the storage. I assume I would create the following
1 Pool with:
vdev 1 RAID-Z 3x 1TB
vdev 2 RAID-Z 3x 2TB
My understanding is that data will be striped across the pool. I will have the equivalent of 2TB on the first vdev and 4TB on the second vdev, with the pool showing 6 TB of storage, correct?
2. Will speeds be impacted by using 1TB drives on one vdev and 2TB drives on the other?
3. Would I be better off using a single 6 drive RAID-Z2 setup?
4. Can I mix and match capacities like that?
5. With RAID-Z1, what happens to the pool if two drives die in the 1TB vdev -- entire pool dies?
6. Can I mirror on vdev to another? (And do they then have to be the same size?)
1 Pool with:
short question. short answer
1. yes
2. some data may striped over both vdevs others only on one vdev, those from first option are faster
3. yes/no two drives can fail but you will use only 1 TB from your 2 TB disks
4. yes
5. yes, finito
6. no
