A few questions about memory
Stonejaw
I just have a few questions about memory I am considering for my next system which I plan to OC and watercool.
I am very torn between Corsair and HyperX, both being dual channel kits, I was wondering which is recomended, I beleive I will be getting the Abit IC7-MAX3 board and I know these boards support DDR400 but I know that lots of people buy PC3700 and up. What exactly is the performance change by doing this?
Also I see that the Max3 supports ECC memory, does having ECC memory improve stability of your system or what exactly is the advantage to this?
Also I would like to ask about timings, I for some reason never learned what timings exactly mean and how much they affect the system speed. If anyone could explain this or post a link to something explaining it would be awsome.
So in general please comment on what you would suggest for memory between corsair and hyperX, I also like hyperX because it is cheaper.
Thanks guys
ECC memory can improve the stability of the system. The downside is the cost. If you use quality parts you will not need ECC memory. So you can save some coin there. Also I don't believe they make good ECC overclocking memory. That memory adheres to strict design specs.
The performance gain of DDR 400 over say 266 is huge. But less so over 333 memory.
In dual channel configuration however a huge gain can be seen. While I could go into some of the timing stuff I won't. It would be best to say that the lower the latency 2.5 or 2 for example the faster the memory actually reads and transfers data.
Dual channelling helps to reduce the increased latencies of DDR vs. SDRAM by interleaving data between the two channels increasing the random read spead of the chips.
ECC memory is supposed to detect and attempt to correct corrupted data to maintain system integrity. That's how it works on paper anyway.
Hope this helps.
