A few questions about converting existing comp?
b18turbo
I have many videos on an extra PC I have and am tired of watching them at my computer desk. So I would like to setup this computer to export to my SD CRT TV. I would also like the audio to go to my TV as well.
I am not concerned at the moment with having the DigitalTV signal go into the computer for capture but will look into that in the future.
Is their a card that will have an RCA out for video and audio and I can simply hook into the TV through video1 or video2 etc.?
I realize that this is a very newb question but would appreciate a response.
buy a vid card or if you have one that gives you s-video out and then buy a cable like this one to connect to composite rca inputs.
http://www.monoprice.com/products/p...=10207&cs_id=1020704&p_id=2846&seq=1&format=2
I don't think they make vga to rca cables, might be able to find a converter. Quality will not be greatest with svideo to compostie rca. Svideo to svideo would be better and cables cheaper if your tv has an svideo in.
If you don't care about the computer and it is sitting around why not sell it and mod an xbox to share the files from your main computer. You could just share the old hd itself in your new machine even. It's is a cool project and would beat a pc being on all the time when you watch stuff.
It has a Radeon 9700 which has a connection that looks similar to Svideo but appears to be slightly different. It is a 7 pin connector... So I can buy a cable like this
http://www.svideo.com/7pintorca.html
Is that correct?
That still won't give me any sound...so to get by I can just hook up some speakers to the computer. What other options do I have?
Edit: I just found this http://www.svideo.com/7pinto3rca.html
This could be all I need?
here you go
If that is your card then it most definitely has svideo from what I read. The svideo plug is that round circle with the 2 notches on it. From what I have seen, it has 4 pins inside when it is svideo to composite rca (the yellow plug). It has 7 pins inside when it goes from svideo to component video (the red, green blue plugs for the newer flat tv's I believe).
Now Svideo only handles video as it is similiar to a monitor connection. Your video card has nothing to do with processing sound and never will. This is why you just need a simple headphone jack to a rca (red/white) cable and you can hook everything up.
The headphone jack to red/white cable is cheap at places like radio shack (10-15$) and the svideo to composite rca is 40$ at radioshack for the 6ft version.
However this cable is 35feet and has the svideo to composite rca cable and the audio cable together.
http://www.monoprice.com/products/p...d=1020704&p_id=2846&seq=1&format=1#largeimage
To paraphrase:
This should be all you need as long as your card supports Svideo out which is found in your cards specs. Your audio is run through your soundcard or onboard sound. I only recommend the monoprice website as everyone on these forums recommends them and have had good experiences with them and the quality of the cables.
but, but, but, but...
I know my post looks great and all that jazz but if you can't read what I stated then what can I do? No that cable may not do the trick and the cable I told you to buy will do the trick but hey, it is your call.
Choose any link for your answer: http://www.google.com/search?q=7+pi...s=org.mozilla:en-US:official&client=firefox-a
Then reread this part of my post "t has 4 pins inside when it is svideo to composite rca (the yellow plug). It has 7 pins inside when it goes from svideo to component video (the red, green blue plugs for the newer flat tv's I believe)."
The other 3 pins are not really needed and do extra work such as component and so on.
The 4 pins work in the 7pins. The cable you keep linking too may not work in your card as apparently the arrangement of the other 3 pins is not a standard and can be different among cable and card makers.
If you have an s-video cable laying around, try plugging it into your seven pin connector. It works fine, i have an x1600 laying here that has the same connector and I just did it. The extra pins are for a composite connection.
If your tv has an s-video port, definitely just plug in an s-video cable and go. If not, check the box your video card came in, most of the time they'll include an s-video to composite adapter.
If what you're really after is composite (no s-video support) then the cable you keep linking should work, just make sure it has a return policy in case the pins are wrong or something. They shouldn't be, i just checked 3 different video cards and they all had the same pinout.
A friend of mine brought over cable that came with his videocard. It is 7 pin to 4 pin adapter and I have a svideo to RCA adapter so that should take care of the video. I also got a 1/8 phono male to RCA female adapter that should work for the audio. Will be trying everything out tonight :)
One more question... does the Svideo port on the video card display a resolution similar to the vga out or is it just an analog signal? Also, I suppose it would be better to lower my computer resolution to 800x600 so that my videos at 640x480 will not have to be scaled up much to run full screen?
