A few issues with Asus A8N-SLI.. stability
1000
HI all.
I upgraded my rig yesterday and have had a few issues with my A8N-SLI mobo.. it seems quite unstable.
The specs are as follows:
Asus A8N-SLI
7800GTX
Athlon 64 4600+ x2
Enermax 535w (with 2 PCI and 24pin connector)
1gig Geil DDR 3500
When I first installed, I was faced with a LOT of instability. My first question to existing A8N-SLI owners is what mobo/chipset drivers need to be installed ? I installed all of them and it seemed to be the cause of instability. I uninstalled all the Nvidia drivers except for the display drivers and rebooted, the system redetected all the drivers required and reinstalled them.. the stability seems to have settled down somewhat. The symptoms are: bluescreening and the rebooting about 30 secs after WinXP loads and a few lockups.
My next issue seems to be related to the Gigabit LAN. Which one should I use for stability, the nvidia LAN or the Marvel LAN ? When using the nvidia LAN I was getting some wierd behavior, such as multiple CRC errors in files and drivers I was downloading, random lockups etc. So I disabled the nvidia LAN in BIOS, uninstalled the driver and used the MARVEL and things seem to have settled down... system is again more stable.
The last issue is the question of whether to use the "nvidia firewall". I think it's actually called something like "nvidia network access manager" or similar.. could this also be causing the CRC errors when downloading files ?
Does anyone have any suggestions or can point me to a Web page where a A8N-SLI "optimisation" or installation guide (for a STABLE INSTALL?) might exist ? The whole A64, nvidia nforce etc is completely new to me (upgraded from an Intel P4 system) and it sure looks like I could use some help getting this sucker stable.
1000
