Just thought I'll finally ask cause I'm too darn curious, haha. Also, most of these questions pertain to my specific rig setup, so they probably won't help anyone coming by for random questions/suggestions.. also some are rather far fetched things that probably have almost no significance but I've just been wondering.. heh
1) How important is giving breathing room to the HD? Basically a standard case (at least mine) has the HDs mounted one on top of each other, with like 2 mm of space in between. My case fits 3 in that configuration, and if I favored one drive over another, is there any "optimal" way to position them? (eg the middle of the three might go to my least favorite cause it's getting heat from top and bottom)
2) On that same note, I have a 4th HD mounted in my cd bay (w/ a HD mount). Do I want to give that drive breathing room too? Does the heat from a HD go up or down? Will there be any danger if I place it close to an optical drive? (I dunno, do optical drives release any type of wacky em field that might fiddle w/ the magnetic HD? I'm sorta pulling possibilities outa my ass).
3) Another similar note - do HDs really "overheat?" What happens when they get real hot? and what exactly is REAL hot?
4) How important are the screws for the HD? I know we want the HD to be as stable as possible, but one of the 3 HD slots I got in my case only has holes for 2 screws - 1 on each side (vs the traditional 4 screws, 2 on each side). Will that play any role in the half-life of my HD? (I dunno, more vibrations = earlier death?)
5) What about software that comes w/ the HD? How does that compare w/ Windows and stuff? For example, for a clean system that I want to build partition and format, how does the fdisk like program that Windows install uses compare w/ something like Maxtor's MaxBlast. Is there a preference in which I use? The lack of a easier to use GUI for Windows is a non-issue. Similarly, what about for existing systems. Windows Disk management vs installing MaxBlast or something like that. Assume that my BIOS can handle large disk sizes and all that jazz.
6) In the days of old, it was recommended that you put 1 HD & 1 optical on one IDE cable instead of 2 HD on one and 2 optical on one. I forget why (I think because you reduce the times you read and write from the same IDE channel), but is there any merit to this?
7) Maxtor (maybe some other companies, but I haven't seen them yet) has ATA133 HDs w/ 16 MB cache... I've seen primarily ATA100 from Seagate and WD. Maxtor supplies what they call an ATA133 IDE cable w/ the HD. Physically, they look identical to the ATA100 cable. Is there actually a difference in the cable? If so, how can I tell?
8) If I have both an ATA133 HD and an ATA100 HD on the same IDE cable, will both HDs work at their respective speeds, or will the ATA100 "bottleneck" the cable and drag the ATA133 HD's transfer speed down to ATA100?
9) Should I quick format or full format a new drive? Or in a way, what actually is the difference? I've heard two different things - full format actuall rewrites all the data to 0s while a quick format just tells the HD that it's all empty, while it's actually there, and the re-write is done as you use that space. If that's true for a quick format, what will the drive look like when you defragment it? Empty or a lot of fragmentted bits? Another thing I've heard is that the difference between quick and full is that a full simply performs a chkdsk first, and that there is no difference between how the format is done. Which one of these is true? (google will show you a link to both theories on the first page)
10) When creating multiple partitions from 1 HD, in the old days of DOS, you were only allowed 1 primary partition. All other partitions would have to be extended partitions created within a logical partition (or vice versa, I forget). W/ WinXP, you can create up to 4 primary partitions on one drive. Lets say you only want 2 partitions and you don't need another bootable partition, would it be better to Create the 2nd partitioin as primary or an extended? And lets say you do change your mind in the future - can programs such as PartitionMagic (or any other prog out there) convert an extended partition into a primary partition? Or basically create a 2nd bootable partition?
and I know I had some more questions.. but i can't remember them now.. so I'll ask as the time comes around
Thanks in advance for any and all replies, heh.
