ThirtySixBelow
- Dec 4, 2004
I'm starting to get confused over all this cpu/memory clock speed stuff. Currently I have an XP 3200+ which runs at 400Mhz FSB. I have to sticks of corsair xms running at 400Mhz. When I am in my bios and look at the fsb speed, it says 200, which i guess is because DDR 400Mhz really is 200Mhz x 2. If i'm wrong there , that might be a start. But, now say I get an AMD 64 3500+ or something with 1Ghz fsb. How does that break down, 250x9? Is it divided 4 times for a bus speed of 250? I'm not seeing how I go from CPU fsb, to what I see in my bios as 200Mhz. With this being the case, memory is causing the same confustion. Say i want to get DDR2 533. Will that be 266 in bios, meaning i will only have 16Mhz of a ceiling to OC with on the fsb? Even so, the timings seem to be low, in this case:
http://www.newegg.com/Product/Product.asp?Item=N82E16820146428
And with this, are the very high ceilings of say the DDR2 1000, only for overclocking purposes. Because DDR2 1000 would lead me to beleive that I could forseeably OC my 250mhz althon all the freakin way up to 500 before the memory would shit. This being the case if you kept the memory speed down to your native cpu of 250, could you lower the timings a whole lot then instead? If i'm totally off someone save me
