A few fan cooling questions
painball
I just built my first PC about a month ago. I am using the Antec Soho file-server case. I just messed around with my stock cooling options today and found they are very limited. The case came with 2 80mm case fans in the rear (1 intake & 1 exhaust I believe). I switched em up and put an intake in the front of the case and exhaust in the rear. I didn't notice any difference in temps. I have always gotten a steady 17* C mobo and a 40* CPU temp (Celcius), which isn't too good.
Aside from that I am planning on adding a few more case fans, probably panaflo. I belive I have only 1 front fitting for a fan, 2 rear, and 1 side. The trouble is that the front is at the very bottom of the case. So intake from there doesn't look like it will do much. I think I might be able to put one in the drive bay though.
As for the CPU temp, is there anything I can do to lower it without buying a new heatsink (using stock).
I think that is all I have been worried about lately. :)
Oh I remember something else I was curious about. Are most fans plugged directly into the mobo or just plugged in with 4-pin connectors from the PSU? Also I am wondering what exactly I have to do to have the "chassis fan speed" show up in my bios, along with the PSU fan. I got the HS fan to show up.
I guess I'll probably have to take a look at my mobo manual.
u can mod ur own blowholes inside the case to increase cooling
you can drill ventilation holes
you can change fans on the heatsinks (depends on your heatsink)
if you ever need anything in your case that it doesnt offer, mod it in (i mod like everything that i have a problem with.... ceiling lamp uses halogen light, too much wattage <300w>, i modded it with a 40w regular bulb....etc, etc, etc) MODDING IS GOOD
you can connect fans with the 4pins, or the 3pins to the mobo or with the 3pin adapter to 4pin
the 3pins are (when connected) for showing the computer what speed its at
