EvilAlchemist
- Jan 11, 2008
I finally found another X5550 C0/C1 revision that supported Turbo Mode.
Now, my main system is running at 2.93 Ghz @ 100% load.
Translates into a 5,000 PPD Boost with A3 (Native Windows)
CPUz is correct with the multiplyer at 22x. CoreTemp seems to have an error with this.
The second update, as you will see in the photo, is all systems have been upgraded from Server 2008 x64 (Vista Based) to Server 2008 R2 (Windows 7 Based)
This also has resulted in a small ppd boost for all systems due in part to the better thread management.
The third update is still a work in progress. Since I have an extra X5550 sitting here, it will be put into my HTPC. I sold my Q6700 today (here on the forums)
I was slightly worried that an X58 motherboard would not like my Xeon X5550 cpu.
After a little looking, i see that is have been done before.
Example 1 - http://valid.canardpc.com/show_oc.php?id=894607
Example 2 - http://i702.photobucket.com/albums/ww29/pastry75/pc_test/Xeon_X5570_D0_ES/default.png
I have ordered the EVGA LGA 1366 Intel X58 Micro ATX SLI Micro Intel Motherboard.
I can only hope that it works correcly - will know in about 12 hours from now
