and the double clicking on a tab to close it doesnt work. only shift+click does. do u know what might be causing that?
berky said:Also, i prefer tabbrowser extensions for my tabbed browsing needs... has more options than anything i've ever seen.
Terpfen said:Double-check your TMP configuration, and make sure it's not conflicting with anything else: the tab configuration in the Options menu, for example. As for removing/reconfiguring toolbar icons, right-click anywhere in the toolbar and hit Customize.
Tabbrowser Extensions is so bloated and buggy that the Firefox developers actually recommend against installing it. So far, that's the only extension they've ever come out against.
Tab Mix Plus is intended to be a non-bloated, non-sucky TBE replacement. It does the job pretty well. I can't think of a reason not to use TMP.
