Dolorous Dave
- Feb 10, 2007
Howdy folks,
I've been reading up on this for a while and there are still a few things that I'm not quite clear on so I figured I'd just throw them out here and see if anyone can help:
1. My E6400 @ 3.2GHz at 1.34V is running under full Orthos load at 56-58C, before the AS5 has had time to settle. I assume this is safe, right?
2. I was told to up the FSBv and the MCHv by .1 each to keep it stable in Orthos--is that necessary? More importantly, is that dangerous to my hardware? I have them each upped by .1V currently.
3. Can any of these voltage settings be lowered? I'm so nervous about the increased voltage damaging my components.
4. I'm stable for 8 hours in Orthos with 1.33V on the CPU and +.1V on the FSB and MCH. Is it possible to loosen my memory timings and get stable at stock voltages?
5. Do temps drop over time once a system has had time to "burn-in"? I'm hoping I can get these temps down closer to 55C at full load over time.
6. Are there any settings in the Gigabyte DS3 BIOS that you'd RECOMMEND turning off?
Thanks for ANY answers or speculation you can dish my way!
