I am on my laptop right now, cause my desktop has suffered the loss of a heatsink.
My specs are as follow:
-AMD Opteron 146 CABYE (OSA146DAA5BN/CABYE 0536 GPMW)
-ASRock 939 dual-sata2 w/ vMod up to 1.55v
-2x256 Crucial Ballistix DDR500
-BFG 6600GT
-OCZ Powerstream 420w
My first question is, seeing how the fan on my CNPS 7700 AL CU died, how feasible is it to run it passive? I have a Coolermaster Cavalier case, so about 2" from the heatsink, there's a 120mm silverstone FM121. I tried a fan transplant (silverstone fm121, another one) and it fell off.
Second: What heatsink do you recommend? I can't use the Thermalright XP 90 or 120 series because my ASRock uses push-pin style bracket, with no backplate, and I don't want to buy a seperate backplate just to use an HSF that doesn't come with a fan. Unless the Zalman CNPS backplate works. I also don't want a Zalman, because I've had 3 zalman's die already, and one of them took out one of my Sandiego's, the other one (a new cnps 9500) killed my Athlon XP.
third: Do you think the Arctic Cooling Freezer 7 Pro series is any good? I can get these locally, and I think that's how I'm going to buy it.
So, basicly, can I run a cnps 7700 alcu in passive? If not, what heatsink do you recommend that:
-cheap
-no backplate, or is compatable with the CNPS 7700 backplate.
-Easy to install
-No lighting. I don't wanna be woken up at night by a heatsink that glows.
-Quiet.
Thanks.
-BFG 6600GT
-cheap
-Easy to install
-Quiet.
Thanks.
