A couple ATI *software/driver* questions
jamezzz122
Why is that little ATI symbol in the taskbar now...I can't seem to get rid of it...
And where can I find out what version of CATs I have, I have the 4.4s but I just wana know how to check...
And also what is the default name for the drivers folder...Because under "Program Files/ATI Technologies/" I have the ATI Control Panel folder the Uninstall folder and a drivers folder but I don't remember what it was originally named since I accidentally renamed it...
:rolleyes:
Your on Windows XP?
If so, right click anywhere on your desktop, and select Properties. Click on your Settings tab, then click on the Advanced tab. Now click on the Options tab and uncheck "Enable ATI taskbar icon application."
That should get rid of the ATI icon on your taskbar and while your at it, you will see which version of the drivers you currently have.
And I'm not sure what the default folder is because I'm not sure if it's different with Omega drivers and CAT drivers.
