A cost-effective cooling solution required! Suggestions pls...
rana
Hi Guys,
I have had this dilema for a while but only now am I starting to feel the brunt of it.
I have a p4 3.0ghz cpu which is not overclocked and is running the stock heatsink and fan combo with some Artic Silver 3 goop in between...
I cannot run my computer with the side panel of my case on because it always overheats and either spontaneously reboots or just plain freezes. I have to keep that panel off.
Because I have to keep this panel off, the fan makes a lot of noise because it is almost always running full tilt. This is because I use my computer for some very cpu intensive purposes...Video Editing, 3d, Music production.....browsing pron... :eek:
Regardless, I would like some suggestions on a heatsink/fan combo which does not cost a fortune but will keep my p4 cool and happy and keep me from unloading my entire .44 into my case.....(just joking...i dont have a gun nor do I condone the use of them in such mundane situations)
Thanks!
I'd also recommend the freezer 7 pro - it's the best price/performance-cooler out there - you can't do a mistake buying this one. I'd also buy a 120-mm-fan for the case-front therefore that you'r in-case-circulation can work better. A 80 mm-outtake-fan in the rear would complete the setting. Buyin' all these products from AC you won't spend more than 40 bugs and will have a verry performant, but decent operating coolin system.
have fun
greets Floke
If you're overheating with a stock cooler at stock speeds then your fan is failing or your heatsink isn't making good contact. You don't need new stuff, you need to fix the stuff you have.
Yep, have to agree with this one. First thing I'd do is CLEAN the system interior. Use a can of compressed air and a vacuum cleaner to catch the dust bunnies. I'd then look into better wire management (if currently, there's a rat's nest of wires). I would remove the stock heatsink/fan unit and clean it, then apply some AS5 (Arctic Silver 5) and reinstall. Turn the system back on (with the side panel off), and monitor your temps. VISUALLY inspect all fans to make sure they are running properly. Run some sort of software that monitors temps and fan speeds, make sure the fans are running at their rated speeds. You may need to replace some fans. If all is OK, replace the side cover and continue to monitor your temps.
P4's (prescotts) do run HOT. An aftermarket heatsink/fan will usually outperform the stock unit, so if the suggestions above didn't help, you may want to consider a new heatsink/fan unit. Also if you have the desire (and space/mount points), you may want to add some case fans, to help with your case's airflow.
