a cool 5.25" fan controller
chronic9
i know theres the NZXT controller, it looks alright, but i havent seen anything about light control as well.
I am looking for a high end fan controller that can also turn on and off lights to go with my TJ07 build.
is there such a thing even? i've looked through newegg with no luck
If one isn't available it's really not difficult to make one. Just get some simple switches and disconnect terminals from Radio Shack and wire them to the +12 line, one switch per light, and mount the switches either on the side, back, top, wherever you feel comfortable drilling a hole.
i am looking for a cooler solution with a lcd screen on it. i guess ill try out the nzxt controller
Its ok you can only change your fan speeds between 40 to 100 percent and cant go between the 10 percents IE 40% 50% 60% Ect.
ill put in an LCD... and then what?
i want this case build to be uber!
