BurntToast
- Jun 14, 2003
The A+ has two tests. The hardware side and then the software side.
As far as taking the tests, is there an advantage with taking one first before the other? Since maybe a few things are covered in both tests or for whatever reason? Or does it not matter what test I take first?
Also, if there a time period that you need to complete both tests? Or can I take one test now and the next test in 18 months and be okay?
Thanks
Thanks
