Undercover_Man
[H]ard Surgeon
- Jan 17, 2010
Hello. I converted from nVidia to ATI because ATI is better from my research. At least when I reviewed their top dog cards.
I want to do dual 5970's. Since 1 card is a dual GPU and 2 cards would be at the max, 4 gpu's, is it still possible to add an nVidia physx card?
Am I right when I say that ATI can't do physx?
If I wanted physx, would I have to do a 5970+5870+physx card? (Basically replacing an ATI gpu with an nVidia gpu)
Assuming I can actually get physx to work, I'll be playing games in a 3 monitor eyefinity mode. Can physx even do that?
I also planned on overclocking the 5970('s) to match or exceed the 5870's clock/mem speed since the only real reason for them downclocking them in the first place was because they wanted to stay below a certain power usage level or whatever. My question for this is, would overclocking the cards (including and/or excluding the physix card) affect anything? Like supposed I didn't OC, how would that affect the 5970 speeds? Doesn't it run at the same speed the lower card run at or do the cards go at their own clock speeds? When I think if this, it makes me think the ATI cards are counted separately as GPU's and the physx card isn't counted as a GPU otherwise the ATI cards would be at the speed of the nVidia card. Would anything change if I OC'd? I just forget how this works.
Would it be possible or even worth doing at all to OC the physx card?
I'm kinda suprised ATI doesn't have a physx type feature. Why is this? I mean nVidia has had Ageia since Feb. '08 and Ageia's card since before then.
I'm wanting to do dual 5970's because I'm maxing out quality over 3 eyefinity monitors. That' in itself will use up a lot of processing power and if I went any lower, the setup would become obsolete quicker than the dual 5970's.
Let me know how this stuff works and I'll be that much smarter. THANX
