UWestSider
- Nov 4, 2004
Hi, all! I'm fairly new to PC building and overclocking. In fact, I just built my first from the ground up. Here's what I have:
AMD Athlon64 3500+ 90nm
MSI K8N Neo2 Platinum
2x512mb PQI Turbo Platinum PC3200 Dual Channel
BFG GeForce 6800GT OC
Swiftech MCX6400-V w/ TT Smart Fan 2
Thermaltake Silent PurePower 480w
I've been able to get the CPU up close to 2.8gHz by upping Vcore and loosening the memory timings. And I installed Coolbits2.0 to try and bump up the 6800GT overclock a bit. I managed one time to get it up to Ultra levels at about 402/1050. That started showing artifacts in 3DMArk03, though. Since then I've been unable to get it past 398/1000. I've seen several posts from other 6800GT owners and also compared 3DMark03 scores -- and I regularly see these cards OCing to 420-430/1100 and up.
So, what am I doing wrong? I'd be happy with 410/1000 or so stable. Is it a heat issue? Voltage? Do I need to flash the bios? Bad PSU? Any other suggestions?
Or should I just call BFG and make up a story about weird fuzzy stuff on my screen or fan noise and try to RMA it?
Thanks!
UWS
Thanks!
UWS
