a build for a friend
silk186
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
gaming
2. Will you be overclocking? (If so, are you looking to watercool?)
yes, but not increasing voltage
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
8000 RMB
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
China, will buy parts from taobao
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need (especially if you will need 3.5" hard drives or expansion cards as these may restrict case options).
case, MB, CPU, cooler, RAM, GPU, PSU, SSD, HDD
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
none
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support? How many USB 3.0 and SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
none
8. What resolution output do you need? 4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output?
1080
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
carry on a plane
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
not
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
important
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
fit in a bag
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
windows 7 64 bit
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
this week
It was a bit difficult coming up with a build as he doesn't have a specific budget or any specific requirements. This is what I have come up with. Let me know if anything should be changed. He has picked the case himself and like the AIO cooler, so unless their is a good reason not to use either.
cooler master elite 130
i5-4690K
Corsair H50
ASROCK Z97E-ITX
Kingston Hyper DDR3 1866 2x8GB
MSI R9 280X twin frozr 3GB
240gb SSD Micron M500 + 2TB HDD ST2000DM001
SEASONIC G-550
Looks like you've picked everything already, what components are you doubting?
I would suggest a SFX PSU rather than an ATX one. Do get a GPU with a blower fan as this will improve cooling in the case and cut noise. You might need to move to Nvidia here. You might also drop the HDD entirely and go for a 500 GB SSD.
I wasn't sure about the PSU, corsair H50 or how everything would fit in the case.
What are the advantages of getting an SFX PSU for this build? will it still hang its ass out the back of the case?
What SFX PSU would you recommend for this build?
If i use a SilverStone ST55F-G instead of the SEASONIC G-550 how would it effect the build?
This is my first SFF gaming build, I put two budget builds together before so I wanted to make sure I had selected suitable parts.
It's smaller, leaving more room inside the case thus easing airflow.
I recommend the Silverstone SFX modular 450W.
