As some of you know I am in a process of gathering components for a NAS build. I am also planing to build a case around it because a classic server case does not do it for me (too much noise in high temperature environment). So, I came to some relative sketch.
Question is, would it be possible to use server backplanes in a computer build? Do they need any special connections to work. I have found cheap on ebay some Chenbro backplanes (80-103214-005 and similar), but I am trying to find some backplane that has SFF-8087 input and SATA outputs.
I know that my question is broad, but is there any characteristic on which I can determine if the backplane would work in regular computer or not? Any connectors that should let me conclude it?
I am hoping to have two vertical columns of 8-10 drives, so many combinations of backplanes are possible, but the best would be four disk backplanes, one beside another and another two on top of them for 16 drives and an option for third column if needed in future.
