A-BIT IC7-G Boot Priority?
GreenX
I've toggled every option I can see reguarding Booting priorities.
I want to boot my RAID which is on SATA (Intel) controller after Floppy and CDROm, so in 3rd spot.
Currently i need to have a HDD hooked to the IDE chains , either IDE1 or IDE2 to boot into my RAID drives otherwise I get that typical "DISK FAILURE< NO BOOT DISK" message.
My old SOYO Dragon had in the 1/2/3 Boot options (when cycled) I could pick RAID/ASCSI in either 1/2/3 boot prioirty. This bord does not, only typical Floppy/CDRom/HDD(IDE)/Zip/Etc.
I even disabled all IDE ports and still can't boot into RAID until I reenable and reconnect my IDE drive. How do I boott RAID over IDE 1st? I just don't see a option. Any help is appericated.
edited for typos and clearer problem.
hit del to get into bios. select Advanced Bios Features. Select Boot Priority. There is also a First Second Third listing below that. Sheesh man download the manual next time.
There is no option below boot priority 1 2 and 3 to make RAID boot 1st
edit
if your talking about Boot Other Device, I already messed with that option and currently have it ENABLED. Did no good.
