A bit help w/ Socket A mobo for Thoroughbred
Mr. Stryker
I have a 2100+ Thoroughbred lying in a Biostar M7VIQ. It was my PC, but it's now dad's, so I'm going to buy a Duron 1.8Ghz for that motherboard since my dad only uses the internet and AIM to talk to me.
Anyway, this socket A CPU is my all-time favorite, and is almost like new. I want to buy a better motherboard for it (has to support PC3200, dual channel) and a heatsink (Thermalright SI-97, perhaps) because I'll want to set it at 2600MHz since its multiplier is locked at 13. I need a motherboard that has options for RAM speed, like set it at 133, 166 and 200. MSI K7N Delta and ABIT AN7 is what I had in mind, but I'd like to hear what you guys think. And what do you think about the heatsink?
13*133=1.73GHz (stock)
13*166=2158MHz
13*200=2.60GHz
Also, my CPU is very cool for some reason. With its stock 60MM heatsink, my idle temps hover 37-39c with a measly 60MM AMD green fan. Yeah...
How about the M7NCG 400? I have the M7NCG (non-400) and it is great. I also have the Chaintech 7NIL1, it too is great. Running on a SI-97 too.
I am upgrading though and will be selling all of it. To bad too, cause I love them both. Oh well, on with the future right? :)
Try these:
Abit NF7-S 2.0
Abit AN-7
DFI LANParty NF2 Ultra B (assuming you can find one)
Epox EP-8RGMI (Yes, it's a micro ATX form factor board. It's the only uATX based on nForce2 that one might consider an overclocking monster)
Epox EP-8RDA series
Asus A7N8X (Regular and Deluxe versions; limited overclocking options, but stable as hell)
Asus A7V600-X
Shuttle AN35N
My folding farm has two A7N8X boards (one deluxe), the AN35N ultra 400, the A7V600-X (it's a VIA chipset - no big deal, though) and the EP-8RGMI microboard (it's in mein wife's PC), so I can personally recommend them. I used to have an NF7-S, but sold it due to an upgrade to Socket 939. Great board - it ran my XP-M at 2.6 GHz.
I'd stay away from those epox boards, and I also don't think that chip is going to hit 2.6ghz
The price difference between PC2700 and PC3200 is negligable, you'd be better getting 3200 to help yourself in the future, downclocking PC3200 to PC2700 should allow you to lower the timings some anyways. To sum it up, dont waste money on pc2700, get pc3200 even if its just value ram.
If you plan on using the SI-97 I'd look elsewhere than the Abit NF7-*, it doesn't seem to mount quite properly due to the components on the west side of the socket. You have to put it on backwards, with the heatpipes facing the RAM. I'm not impressed.
(Spoken from one who's using one now.)
Oh, allright. But I decided to go with the AN-7, it seems to be compatible on that one. Is it true the 2100+ Tbred's multiplier is locked at 13? Can't put it lower?
all the tbreds I ever used were unlocked, I had a 2100 and 2.3 was the highest I got, and it wasn't totally stable, 2.2 or so was. used a Soyo Dragon Platinum, but the NF2 motherboards should do much better, esp Abit or DFI. Good luck !
My friend got his 2100+ Tbred up to the 2400Mhz -ish range, obviously favoring a decent FSB (208+).
I'm not quite sure he could get up to 2600Mhz+ though like my XP-M could. 2600Mhz for the Barton took at least 1.75Vcore for me (~1.80 real world). My friend was already putting 1.8Vcore just to hit the 2400Mhz range on his Epox mobo, so who knows.
My A7N8X doesn't have the 13x multiplier...but his did. If you are RAM/chipset limited, then the multiplier will be easier. Aish.
