Expanded from this thread: http://www.hardforum.com/showthread.php?t=1327398
Initially I thought the problems were with the video card; someone suggested occt, and then the problems really began..
cpu at stock speed / volts; nothing overclocked, everything cooled well. OCCT crashes usually after 1 minute, with error code 1 or 4. Could it be a bad cpu, or should I look elsewhere?
Specs:
Intel E4300
Asus P5Q Deluxe
Visiontek 4850
2x1gb OCZ Gold PC6400
Silverstone ST50EF+
4x hdd
Scythe Infinity cpu cooler
Temps:
both cores usually idle around 37c, load around 45c. GPU is usually 63 idle, 66 load.
Thanks.
Specs:
Intel E4300
Asus P5Q Deluxe
Visiontek 4850
Silverstone ST50EF+
4x hdd
Temps:
Thanks.
