yellowdisplay
- Dec 29, 2008
I was considering the NEC EA241WM ($549 MSRP) but couldn't find what type of panel it was. Given the viewing angles (160), I suspected it was a TN. However, I chatted directly on-line with someone at NEC Tech Support, and here is the transcript of the conversation:
Sent: Mon 12/29/08 5:26 PM
You have been connected to Rudolph Malmgren.
Rudolph Malmgren: Hello how may I help you?
Customer: Is the NEC EA241WM a TN panel or a PVA panel? Conflicting information on the web. Thank you.
Rudolph Malmgren: Give me a moment to look that up.
Customer: Thank you. the 19' EA series is PVA, but no mention of the 24" model... thanks.
Rudolph Malmgren: The EA241WM-BK is an S-IPS panel.
Customer: An S-IPS panel??? Are you sure? $549 would be an unbelievable price if it is. Can you double check?
Rudolph Malmgren: I'm looking at the breakdown in our data base and it lists the panel type as S-IPS.
Customer: Thank you then. It's just that all of the other 24" S-IPS panels are at least $1000 and above...
Rudolph Malmgren: I know that it is becoming cheap to manufacture S-IPS panels and prices have been coming down.
Customer: Ok -- thank you again for your help. I'm putting my order in then... Thanks again.
Rudolph Malmgren: Any thing else I can help you with.
Customer: No, thank you.
Customer: Have a nice evening.
Any thoughts? It sounds too good to be true, but this is was NEC says... any of you forum-ers with more information? Thanks.
