I am upgrading my Solidworks workstation and would like feedback if there are any places to improve performance. Solidworks tends to like high clock speed and fast storage, with seems to be optimized for intel CPUs at this time.
This machine is dedicated to CAD work only; all simulations are done on a separate thread ripper workstation.
This is in my home office, and noise reduction is a big priority. Does anyone make a water block for the Radeon Pro card? I was unable to find any specific blocks, might try out a universal block if needed.
· 9900K
· Radeon Pro WX 8200
· ASUS Intel ROG MAXIMUS XI GENE Z390
· G.SKILL TridentZ 32GB (2 x 16GB) 3200
· Intel Optane SSD 905P Series M.2 22110 380GB (mounted in vertical DIMM.2 slot?)
· Corsair HX1200i (oversized to run in fanless mode most of the time)
· EK CPU block
· Remote Koolance EXC-800 chiller
· 9900K
· EK CPU block
