MrWizard6600
- Jan 15, 2006
All images taken from VR-zone and Xtrems-systems forums.
http://www.vr-zone.com/articles/GeForce_9900_GTX_Card_Design_Exposed/5763.html
GT200. Can't tell you how happy a single die makes me, I was afraid the GT200 was going to be some kind of frankin-dual-G92b's.
edit: man VR zone is so much better than everyone else for speculative rumors. When they post something, its usually pretty concrete, unlike some people.
edit2: what I know about specs:
- 10 SP banks, each with 24SPs, for a total of 240.
- 8 ROP sectors, each containing 4 ROPs (32 units total),
- Each sector connected to a single 64bit memory controller, 512bit bus width total
- Clocked at a reasonable speed for .8ns memory that leaves you with over 125GB/s total memory throughput without breaking a sweat.
- 65nm, but NV is threatening to move it to 55nm so long as the G92b (first 55nm from NV) isn't bleeding too bad (which we'll find out when the 9800GT is released or delayed).
- 1024MB on referance design, spread across 16 GDDR3
() 64MB chips (my bad, I knew it was double sided but just sorta forced the numbers to fit).
- 240W TDP (!!!) per die. If my information holds true, Quad SLI will require (and I'm the guy who thinks I can SLI two 8800s on my 550W) PSUs above 1KW.
- Stock will be dual slotted cooling, and will require something of a no-nonsense design (perhaps like ATIs stock HD3870X2 cooler).
- 2nd core from NV to use an IHS.
- $500?. If you've ever taken a look at Fud's front page its always pro ATI anti NV, so I take him saying $500 to mean "at most, $500"
