$99 PVR250MCE (oem)
killernoodle said:
Whats the difference between the 250 and 150 then?
The 150 is built with a single chip instead of 2, making it cheaper. So the 150 is bassically the same thing, with the same quality, but doesn't cost as much. Although, as stated above, there's not as good support yet.
will the mce work fine with normal versions of winxp in non-htpc situations?
There are three functional differences in the MCE and the standard 250 that I remember. The MCE does not have the build in remote control receiver. The MCE has standard RCA jacks for the audio instead heaphone type jack on the standard. The MCE also has an FM tuner.
I have the 250MCE and it works great for me but I haven't really used it for much outside my HTPC.
Edit:
I'm running Windows XP home on my HTPC.
Damn! ever since finding this site, i'm gonna have to get a second job.
Just ordered mine, was wanting to finish my media center PC.
thanks for the link.
QM
Wrong.
The 250MCE is the media center edition of the 250.
The 250 has hardware vcd encoding, which the 150 does not.
you are not the first person i've had to tell that "the 250 and the 150 are not the same card"
http://www.hauppauge.com/Pages/compare_pvr.html
WinTV-PCR-150
Model # : 1045
PCI Bus
Mpeg2 encoder : Hardware : up to 12MBit/sec
Mpeg2 decoder : Software
Raw Avi Capture Supported? : NO
dbx Stereo : yes
FM Radio Stereo : NO
Remote Control : YES
Svideo Input : YES
Composite Input : YES
Audio In : YES
Video CD Encoder Hardware : NO
Win TV PVR-150 MCE is identical, except it *DOES NOT* have a remote controlIt does, however, add stereo RCA Jacks for audio input, and fm radio
Win-TV-PVR-250
Model # : 980
PCI Bus
dbx Stereo : yes
Svideo Input : YES
Audio In : YES
Video CD Encoder Hardware : YES
The WinTV PCR-250MCE is the same, except, again, you guessed it.. : NO REMOTE control
The 350/(no mce version) adds fm radio to what the 250 does
The 500, is the 250 with TWO tuners (and not, as some have said, the 150 with 2 tuners)
Now.. do you need video cd hardware encoder? Probably NOT.
Which is why I tend to go for the 150, myself.
Laforge said:
Wrong.
WinTV-PCR-150
Model # : 1045
PCI Bus
dbx Stereo : yes
Svideo Input : YES
Audio In : YES
Win-TV-PVR-250
Model # : 980
PCI Bus
dbx Stereo : yes
Svideo Input : YES
Audio In : YES
thanks for clearing that up! I almost bought the 250. Going to get the 150mce
350 also adds a hardware mpeg2 decoder with an svideo out dongle. as far as support, most of the 250 compatible programs have worked with the 150, but they are not all certified yet, so you ae taking a chance.
