- Nov 11, 2012
I was taking benchmarks and didn't realize I had REBAR turned off. So, I have bencharks with, and without REBAR for comparison.
I'm using 2x8GB 5600MHz SO-DIMMS with adapters to run at 4400MHz at 30-30-30-60-90 with an i7-9850X3D (+200 Boost, -30 CO). For the graphics card, I'm using a PNY RTX 5070 Overclocked Triple Fan (+400 Core Clock).
CPU-Z Single:
Without REBAR = 892
With REBAR = 895.7 (+0.4139%)
CPU-Z Multi:
Without REBAR = 9158.7
With REBAR = 9115.2 (-0.4761%)
Geekbench 7 CPU Tests:
Single Without REBAR = 3128
Single With REBAR = 3127 (-0.032%)
Multi Without REBAR = 19248
Multi With REBAR = 19125 (-0.641%%)
Y-Cruncher Tests:
Without REBAR = 21.449 seconds
With REBAR = 21.364 seconds (-0.397%)
Geekbench 7 GPU Tests:
CUDA without REBAR = 309936
CUDA with REBAR = 317308 (+2.351%)
OpenCL without REBAR = 209536
OpenCL with REBAR = 217224 (+3.603%)
Vulkan without REBAR = 187412
Vulkan with REBAR = 188101 (0.367%)
Cyberpunk2077 High Native 2K:
Without REBAR = 132.31
With REBAR = 136.23 (+2.92%)
Oddly, it seems that the CPU speeds are slightly slower and memory speeds are slightly faster, but it could just be variance. However, the graphics card performance saw a definite increase in speed (up to 3.6%). I wonder if an AMD graphics card has the same result? Maybe I'll test that out some day.
CPU-Z Single:
Without REBAR = 892
CPU-Z Multi:
Y-Cruncher Tests:
