I left this for 6 hours in the 4.3's thread but no response, damn OCP'ers getting rusty in their old age.
I upgraded to the 4.3's on the 11th and now seem to be getting a few problems but don't know if it is related.
First and foremost my computer seems to be more unstable, it seems to be linked to Rivatuner (14.3). Whenever Rivatuner is running I get random crashes to the desktop which never happened before. Turning it off solves it.
I am now also getting the white spots on textures that I used to only get when I oc'd a tad too far. I'm running 440/800 but it was always fine before.
X2 is running really slowly now I used to run 1600*1200 2xAA no worries but now it can't do 1280*1024 2xAA without crawling on SETA. Bit odd.
Do you reckon it's the drivers or just a random bork. I'm not sure as it just seems like odd symptoms to have for a driver problem.
Main Components are;
P4 3.0 oc'd to 3525
IC7-Max 3
1GB Corsair Ram
Asus 9800XT @ 440/800
SB Audigy XS2 Platinum Pro
2*160GB Maxtors RAID 0
Sony DVD/R
Other shit like Z680's and my USB devices wouldn't really make a difference would they but there is a new IR device I've installed this week as well.
How should I take this forward?
P4 3.0 oc'd to 3525
IC7-Max 3
1GB Corsair Ram
Sony DVD/R
