9800XT Reporting As R350?
CSx-2011
EDIT:
Aida16 says:
Display Adaptor: R350
3D Accelerator: R360
I guess its all good then!
Just picked up a new XT for a good price. Works great, but...
Using the utility called "Display Adaptor Information" under maintenence (on stock catalyst cd) it says the core is R350.
I was under the impression that XT's were R360's. Is this normal? And would anyone with an XT check and see what yours says for me?
Thanks, CSx
ALSO, can anybody with an XT tell me your normal temperature range on the GPU...
This doesn't deal with you directly, but hardware reporting is often off. My Radeon 9800 NP reports as a Pro, and I've heard of various other cards reporting as something slightly different than what they should be.
I was wondering about that... r350 and r360 are essentially the same thing...
Someone with an Xt check it out and tell me!!! :p
Thanks
What's your clock speed? Does it monitor temps? If it can monitor temps it's an XT core (R360).
edited for a typooo
Yeah, it has the temp probe and overdrive...
Aida16 says:
