9800XT Confusion: Different Power Sources?
—§urfÅceЗ
I'm confused...again. My computers internal PSU is 230w. Now I've got an external power supply, that my computer, PDA, and monitor connect to. It's a CyberPower generating 325w.
If I buy a 9800XT, is it required to connect to my computer internal PSU? And if so, how much power should my PSU have?
yeah it will have a normal molex type connector. similar to the power connector on a hard drive or cd-rom
I run my athlon xp 3000+ off a 300w with my 9800 pro.
I wouldn't recommend going lower than a 300w.
A 9800XT consumes a lot of power (because it was basically pushing the 15nm process to its max). I would strongly recomend buying a 6800nu instead; you can probably find it for cheaper, it will perform better, and it will consume a lot less power.
http://www.xbitlabs.com/articles/video/display/ati-powercons_7.html (9800XT)
http://www.xbitlabs.com/articles/video/display/ati-vs-nv-power_4.html (6800nu)
In fact, the 6800nu only consumes about 38W of power (the AGP port can deliver up to 45W, I believe) so theoretically it wouldn't even need an extra molex. The 9800XT, on the other hand, conumes about 60W of power at full load.
In your case I feel that the 6800nu is a much safer card to go with (but you still might want consider upgrading your PSU).
Ok...I am having troubles finding your 6800 non-ultra in AGP (assuming it has 128MBs). I have searched numerous places...
Do you mean the 6800GT? That one doesn't look like much of a power saver...
http://www.newegg.com/Product/Product.asp?Item=N82E16814140067
http://www.newegg.com/Product/Product.asp?Item=N82E16814121216
Normally, I would recommend that you spend $50 more (or $30 if you're looking @ the Asus) and get a 6800GS which would be MUCH better, but since power consumption is an issue here, this is about the best you can get in AGP without needing a new PSU.
You want to look for something that doesn't have an external Molex connector; if it does, then that's more load on your PSU. A card that doesn't have it means that it sucks all it's power from the AGP slot, and there is less load on the PSU.
