9800XT at 61 Celsius...
TimmerUK
Sorry to ask questions that have probably already been answered, but the search function is still down...
I just loaded 4,1 drivers and noticed VPU temp at 61
Any comments shouls I be worried
Cheers
Timmer
that should be fine, ive heard that gpu cores run a lot hotter than cpu cores
Cheers
Timmer
61 is just fine
Originally posted by retardedchicken
i dunno if this is comparing apples to oranges but my 9600XT runs at 30-35C...
my 9600xt is 36c idle, jumps up to 50c after playing NFS-U for a half hour. clocked @ 526/335
overclocking video cards(or anything for that matter) is usually luck of the draw, some will OC amazingly and some will suck
also, will my video card get artifacts before it gets too hot or will it heat up before artifacts?
