9800se 256 bit for $121 shipped
Great deal if the information listed there is correct. Not trying to down this deal but there are a few things you have to consider.
1) while a decent company, GameVe has misrepresented video cards and other hardware before.
2) The Heatsink is not the standard 9800 one, it looks almost like a 9700 pcb too
3) Powercolor was the company noted to have 9800se's with 256bit...what company manufactures this one?
Good luck either way
I just looked at the Powercolor card here, and the similarity is uncanny. Also, Powercolor is bundling their X800 cards with Hitman: Contracts. This card comes with Hitman: Contracts. I do believe this is a Powercolor 9800SE.
CleanSlate said:
It's a BBA (built by ati) card, is it not a hot deal? For a card that can out-do a 9600xt at stock speeds (and is cheaper than a 9600xt!... I'd say it's very much worth the money even if I wasn't softmodding this bad boy!
~Adam
How do you know it's a BBA? I checked the description, and it says nothing about the brand name. It's "Powered by ATi," which means nothing other than the card is using an ATi GPU.
they did make both 9800se 256bit on 9700 pcb and 9800 pcb's, usually powercolors will tend to use the 9800 pcb's while sapphires usually use the 9700 pcbs. generally the 9800 pcb versions send to softmod with better success
yea but as we all know those speeds are just default. I'd be willing to be (hell I bought one, I AM betting) that it's going to have 2.8ns ram on it.
~Adam
bought myself some copper ramsinks from fry's for 13 bucks and some 8 dollar arctic silver thermal adhesive and I'm ready to rocknroll on this 9800se.. God help me :)
~Adam
anyone know if this works for sure?
edit: what is involved in flashing this card... is it just a set of drivers or harder... bios etc
flashing refers to bios flashing which isn't drivers but if you want to "softmod" it to 9800pro it would work with only drivers. I dont plan on flashing but I might end up doing it if the softmod works just to see if it helps performance.
Edit: lots of ppl have done this but none that I've seen that have gotten it from this site, I'm the first I think. Although it does appear to be the same make and model powercolor that is ussually good for softmodding.
~Adam
Looks identical to mine which softmodded perfectly. YMMV. I have the Hynix memory.
Of course mine now looks similar to a HIS with the arctic silencer and alum. ram sinks.
Stock speeds were 380/680. Now @ 430/740
This deal is just so tempting, make sure you post your softmod results CleanSlate.
wickedld9 those are some nice results with Hynix ram onboard, looks like the stuff may not be so bad after all.
I will def put up the results and pictures and .. and lots of benchies n stuffs. This is my first mid-high range video card and I've wanted a 9800pro since it came out... I'll be trying to hit xt speeds :D
However I think I messed up my motherboard =/ more about this problem in the motherboard section.
~Adam
its now 125 dollars plus 5 bucks for fed ex express saver
still cheaper then the egg by 20 bucks
although the model numbers look the same
gameve reports the card as 270/275
egg shows the card as 380/275
big ass difference but i dont think gameve updated they shit
I got my card!!!
Yes they underclocked it to try and make up for the price diff.. but it clocks right back up to regular 9800se/pro speeds easilly. However the ram is 3.3ns ram instead of the 9800pro/9800se type2 spec'd 2.8ns ram so there's where the lower price comes in.
I love it so far! I'll post my benchies later, time to play!
~Adam
CleanSlate said:
I got my card!!!
~Adam
Are you going to softmod it ?
Already did, runs GREAT, check out the sig!
Pretty sweet deal for $121, I dont mind the slower ram that much.
~Adam
So with the soft mod what does that mean??? Is it like a 9800 PRO??? Or what? I'm looking at getting a new vid card, but I'm not sure on a refurb 9800 PRO, or a new one. If I can get good results for less on this card, then I think I'll save the $40-$80....
buy the retail version from newegg
its 145 and comes exactly the same as a 9800 pro(2.8ns ram/same frequencies0 but only with 4 pipes
then u have a 50/50 chance of softmoddin it to unlock the other 4 pipes
