9800PRO or 6800?
emoretared
Donno if i should drop the 175 for a 9800pro or save a little for 6800. is there a huge difference?
Always save for next gen card if you're even considering
Especially since you even have that thought in your mind, chances are you'll be regreting it later if you don't
I upgraded from a 9800 pro to 6800 and its a *huge* difference.
If you got the cash, or can get the cash in a reasonable time, do it.
I had the same question when i was upgrading from my gf3ti200. Definately go with the 6800. Great card and its the latest generation.
There is a big difference, especially 9800Pro vs 6800GT. I am a believer now.
