9800pro.. OC or flash to XT? or both?
RancidWAnnaRIot
EspantaPajaros
Okay.. i soon plan to get the sapphire 9800pro and a VGA silencer with it.. If it's the R360 core, am i better off flashing it to an XT, or just OCing it....and what about flashing it and then OCing it?...
Also... we all know that OCing a CPU kills the life of the CPU, but it doesn't matter since the CPU will still last pretty long... my question is.. how much life will the average OCed vid card have? IS it the same situation as OCing a CPU?
Thanks
flashing it gives you the optimized shaders (i think thats what they improved) which gives you mabe 200 points extra in 3dmark03, just overclocking wont make it a true 9800xt
make sure it can stand the xt speeds before you flash it though
as to the life of an overclocked card...all i can say is that the only components ever to die on me have been the video cards, any processor ive had (most werent really overclocked though) still works years later, but ive had 2 or more video cards die for unknown reasons, some which i never even overclocked, and others as a result of physical damage from me overclocking ;D
i guess video cards are just more fragile is what ive found
I see i see.. i have a question about ATI tool... would it be wise to use the tool that only overclocks the programs i specify? Would that help prolong the life of the Vid card?
I guess what i'm asking is.. is it okay to leave this card Overclocked all the time?
