9800Pro - ATI or Sampphire?
codeflux
considering upgrading my 9700pro to 9800pro/128 - yeah, i know, marginal, but i'm seeing mad overclocks on 9800pro (like 500 on GPU) and my 9700pro tops out at ~400 on GPU with a voltmod.
so, is there any difference (in quality, overclockability, performance) between a 9800pro made by ATI and the same made by Sapphire?
i figured i'd ask first, just in case. i don't see any difference myself... this upgrade will run me in the order of $100, so it ain't that big of a deal. i want this to last me until RV420 comes out (or whatever the new core will be called).
here are the links: Sapphire for $268 and ATI for $298.
sapphire is OEM, ATI is Retail (who needs it?) - for a $30 difference
A 9700 pro with a 400mhz core is plenty to hold you over until the next gen.:eek:
9800pro with 500mhz gpu ?!?!? where and with what cooling? Prommie2 modded to a gpu?
If u wanna volt mod the Pro any will do:
Here's a 9800 Volt Mod Guide:
http://www.fastlanehw.com
IF NOT, the retail ATI cores overclock highest (mine does 490 stock on air) Sapphire's oc highest on memory. The R350's performance is GPU driven & not reliant on memory bandwidth so much (like the R300's were).
So buy the retail ATI if you're a serious benchmarker.
