9800pro => 6800nu (or x800pro)
Chaballaman
How much performance increase would i see from 9800pro to 6800nu?
and how much faster is x800pro compare to 6800nu? 6800nu is cheaper than x800pro which only comes in 256mb..
Also which card runs cooler 6800nu or x800pro? and is 250w psu enough for the card?
In most cases people see a 40-50% performance gain. X800pro would easily beat the 6800nu. 6800nu is more comparable to the 9800XT, or it seems that way. You should get a X800pro or a 6800GT. I ordered my eVGA 6800 GT yesterday from the eVGA's website and it comes bundled with Farcry. X800pro's are hard to find now, expecially ones that are bba. I think Vision Tek's X800pro just got certified and has them in stock at their site too.
I would go with the X800 pro. Its faster, only uses one PCI slot in your computer and consumes less power. I just picked one up yesterday and immediately got an overall performance gain of 25 to 30% over my previous 9800 pro. Remember, the new cards are bottlenecked by processors meaning the faster your processor the better performance gain. Check out this article http://firingsquad.com/hardware/x800_pro_athlon_xp/
There is also a intel version out there. :p
What is bba? And, are these other variations of the x800 out there better than just getting one built by ATI?
Hahaha i'm a dork. :D I just checked out the xtasy x800 from vision teks site, 399.00!! 62 bucks cheaper than newegg. I think I see some advantages right off the bat.
i don't intend to start up another NOO ATI .. NOOOO NVIDIA! war .. but just to clear up some things,
the 6800GT is also a single slot solution with 1 molex plug and has basically the same power requirements as the x800 pro. you may want to do just a little more research yourself to decide for sure which is right for you.
The x800pro is faster than the 6800nu. The 6800nu is faster than the 9800xt. The 6800GT is faster than the x800pro.
To see how they stack up:
http://www.anandtech.com/video/showdoc.aspx?i=2113&p=4
Here is a comparison between the 6800 and the 9800XT
(win = 5fps or higher score than the competition, * means the card won by 10fps or more, tie means score difference was less than 5fps)
6800 vs 9800XT
Aquamark - 6800 win
no AA/AF
EVE: The Second Genesis - tie
FarCry - 6800 win*
Final Fantasy XI - tie
Jedi Knight: Jedi Academy - 6800 win*
Unreal Tournament 2004 (1280x1024) - 6800 win*
Unreal Tournament 2004 (1600x1200) - 6800 win
Wolfenstein: Enemy Territory - 6800 win*
X2: The Threat (1280x1024) - 6800 win*
X2: The Threat (1600x1200) - 6800 win*
4x AA/8xAF
F1 Challenge (1280x1024) - 6800 win*
F1 Challenge (1600x1200) - 6800 win
FarCry - tie
Halo (1280x1024) - 6800 win*
Halo (1600x1200) - 6800 win*
Homeworld 2 (1280x1024) - 6800 win*
Homeworld 2 (1600x1200) - 6800 win*
Neverwinter Nights - 6800 win*
Unreal Tournament 2004 (1280x1024) - tie
Unreal Tournament 2004 (1600x1200) - tie
Warcraft 3 - 6800 win
X2: The Threat (1600x1200) - tie
Remember, the $210 9800pro is significantly slower than the 9800xt.
The results from anandtech above show that the 6800 beats the 9800xt in most games, often by 10fps+ with a few exceptions.
PNY 6800 - $250
http://www.buy.com/retail/product.asp?sku=10376098&loc=101&sp=1
eVGA 6800 with FarCry - $289
http://www.newegg.com/app/ViewProductDesc.asp?description=14-130-202&depa=0
If you can spend the extra cash, though, the $399 6800GT with Free Farcry is by far the best value out today, especially since its a 16x1 part unlike the x800pro and can be overclocked to 6800U speed most of the time:
http://www.evga.com/products/moreinfo.asp?Part_Number=256-A8-N344-AX
A 6800GT can be had for this and you'll be better off.
I'mma say get the 6800GT, because I don't think anyone has had a problem overclocking them to Ultra levels. Best Bang for the buck, but you really can't go wrong with x800pro or GT.
http://www.evga.com/products/morein...=256-A8-N344-AX
I just saw this from another post in the forums, read through it, and then came here to post, lol. This is very interesting. Seems as though I need to keep researching.
I like this kinda power for that kinda money.
6800 gt all the way. The 6800 non ultra has the same memory bandwidth as a 9800 pro 256 mb, in effect castrating it. Remember that gpus have been evolving a lot faster than memory, so using older memory has a much bigger impact on performance.
