the VGA Silencer is a generic cooler for just the GPU, it should fit on a number of cards. the other ones are specialized to a particular card, and they cool the ram chips as well.afropuff said:What's the difference between the VGA Silencer Rev 3 and the ATI Silencer Rev 1,2,3,4,5 ??!?!?!?
-fro
trajik78 said:the VGA Silencer is a generic cooler for just the GPU, it should fit on a number of cards. the other ones are specialized to a particular card, and they cool the ram chips as well.
there is no Ati Silencer for the 9800Pro. The one you have to get (cause it's the only one that fits the 9800) is the VGA Silencer. And to cool your ram chips i'd get either the OCZ or Vantec copper ramsinks. they fit nice nice under the Silencer.afropuff said:Sooooooo...if I WERE to get one for my 9800 Pro, it would be "better" to get the ATI Silencer Rev that fits my 9800 Pro over the VGA Silencer Rev3 ??
And is it really worth the extra $$?? I can get the VGA Silencer Rev 3, for around $19 shipped from Newegg, where the ATI silencer Rev's seem to be $17-20+ just for the card w/out shipping, so it would probably be over $23+ for the ATI Silencer and a difference of about $4 or so between the VGA and the ATI.
-fro
trajik78 said:there is no Ati Silencer for the 9800Pro. The one you have to get (cause it's the only one that fits the 9800) is the VGA Silencer. And to cool your ram chips i'd get either the OCZ or Vantec copper ramsinks. they fit nice nice under the Silencer.
Uhh, the 9800 128MB and the 9800 Pro 128MB are the same cards. The ATI Silencer 1 can fit on both. The 256MB cards, however, require a different solution.trajik78 said:there is no Ati Silencer for the 9800Pro. The one you have to get (cause it's the only one that fits the 9800) is the VGA Silencer. And to cool your ram chips i'd get either the OCZ or Vantec copper ramsinks. they fit nice nice under the Silencer.
i was just about to repost and say that._Korruption_ said:Uhh, the 9800 128MB and the 9800 Pro 128MB are the same cards. The ATI Silencer 1 can fit on both. The 256MB cards, however, require a different solution.
