9800n gx2 overclocking
wadec22
What kind of overclocks are you guys getting with your 9800gx2? No references to websites please. I am looking for results from actual owners of the card.
Anyone have their hands on aftermarket cooling for one yet? Thanks!
740 core 2280 memory 1847 shader on stockcooler ATM and on stocksettings for the fan and that is as high i want to go on air.
Has an EK FC9800Gx2 Sli that i will put to use later next week when i change the motherboard to before i push the card harder.
There will be hard to fix anything else but WC-block for Gx2 as the heatload is massive from 2 cards on just one cooler and the way the card is build it will be a hard time to do anything with it.
With SLI off i was able to hit 750/1875/2200, with sli on, i was only able to hit 725/1825/2200. But overclocking doesnt really seem to push the temps up all that much.
Hmmm... my core is kinda weak, freezes at 700. Stable at 695/1800/1145(2290). No worries really, not going to keep it oc'ed since these things get so warm and I'm using air.
740/1850/2200 in SLI is what I amd getting. But I have 3 88cfm fans blowing on them from the side of the case (Gotta love MM cases).
Anyone know if the gx2 has the same issue as the GT with migration on the memory bus if pushed too hard for long periods of time?
